Trans Leak
Old Sep 16, 1999 | 06:29 PM
JA_Stang86's Avatar
Angry Trans Leak
6275 mi and I took it in for a small tranny leak. Two days later I am told I may get it back monday. The front seal was leaking due to a casting defect in the torque converter where the spline goes. Part won't be here untill monday.
1999 F150 Lariat
Reg cab Short box Styleside
5.4L 3.55ls
Deep Wedgwood Blue/Silver
Lund Interceptor hood shield, VentVisors, Class III hitch, Ford molded mud guards, soft tonneau, factory CD with changer (thanks Dusty), tinted windows
Menasha, WI
http://www.fortunecity.com/silversto...ton54home.html
Old Sep 22, 1999 | 05:59 PM
JA_Stang86's Avatar
Question
Well I finally got my truck back today, with new torque converter, I think. Reading over the invoice the items I am questioning are,
Part Number: Desc: QTY: SELL:
FMC F85Z 7902 AARM *converter ASYREMSPO 1
FMC XL3Z 7902 AARM *converter ASYREMSPO 1 150.45
SPO XL3Z 7902 AARM *converter ASY REMFG 1
The first and third numbers have no price but have a quantity of 1. Does anyone know for sure whet these mean? Please tell me they did not put a remanufactured torque converter in my truck with only 6K mi on it. I am not real familiar with transmissions, can a torque converter even be rebuilt?
Jeff
1999 F150 Lariat
5.4L 3.55ls
Menasha, WI
Old Sep 22, 1999 | 07:27 PM
TELLENBERGER's Avatar
Post
Yes, torque converters can be rebuilt. But, some are welded together and I wouldn't think it would be worth the time and effort.
Where is Menasha? I did my first 17 years in Racine; about 30 miles from Milwaukee.
97 F-150,4.6, Reg Cab, Flareside, Air Aid Kit, TransGo Shift Kit,
Superchips, Gibson Single Cat Back, ******* Bed Cover,
EGR Bug Shield, XL Full Length Running Boards,
Hellwig Rear Sway Bar, Hellwig 2500# Overload Springs
Old Sep 23, 1999 | 06:05 PM
JA_Stang86's Avatar
Cool
Menasha is at the northern tip of lake Winnebego, 25 mi south of Green Bay and 20 mi north of Oshkosh. Thanks for your input, runs good so I guess I won't mess with it.
Jeff
1999 F150 Lariat
5.4L 3.55ls
Menasha, WI
Old Oct 19, 1999 | 02:24 PM
54regcab's Avatar
Angry
Damn I've got the front seal leak too.
only 3,300 miles.
Should I take it back to the dealer where I bought it 45 mins away or just take it to the dealer about 5 mins from my work?
Is there any advantage to taking it back to where I bought it?
The guy who has been changing my oil for the past 3 years showed it to me and said I should ask for a new tranny.
Is this reasonable/possible?
Please reassure me that I did the right thing buying a Ford.
3,300 miles is way to early to start having problems.
99 XLT 5.4L reg cab 4x2 120" Wheelbase 4 wheel disc brakes/ABS 5 star larait style wheels Toreador Red/Silver 3.55 gears 255/70/16 OWL Delta toolbox
Eclipse 5340 cd player
Memphis ARCS50 component speakers w/tweeters mounted flush in the door panels (excellent sound)powered by a Sherwood 35x2 RMS amp
Jensen 50x2 RMS for the 2 Audiobahn AWC10 subs
Looking for reasonably priced used running boards
54regcab@duesouth.net in Columbia SC
Old Oct 19, 1999 | 04:30 PM
J-C's Avatar
J-C
Thumbs down
I'd take it to the most convenient Ford Dealer and "report" the problem. If you wish to "demand" a new tranny, then take it to the Selling Dealer.
I think you'll get better service under your warrenty by just reporting the problem and letting Ford fix it. My .02.
Good Luck.
Sorry to hear about your leak...
Old Oct 28, 1999 | 08:11 PM
54regcab's Avatar
Red face
OK as a follow up I took it back to where I bought it and they gave me a loaner so the 45min drive was not a problem for me.
Still no word on what is wrong or when it will be ready.
Old Oct 29, 1999 | 01:33 PM
54regcab's Avatar
Thumbs up
Got my truck back today.
Here is what they replaced:
1: PMP & PST ASSY-TRANS
2: GASKET-TRANS GEROTOR
3:SEAL-TRANS-FRONT
4: 12 TRANS FLUID
Labor
1:trans assy R&R
2:seal - front pump or convertor - replace.
3:road test
Cost with labor $396.15 (warranty covered it)
Old Oct 29, 1999 | 02:30 PM
Stephen_T's Avatar
Post
54regcab: Same thing happened to my '99 5.4 at about 3800 miles. Your parts list looks similar to mine. So far so good at 9100 miles. No more leaks and the tranny works fine.
Old Oct 29, 1999 | 06:25 PM
Dunbarton's Avatar
Post
54Regcab,
You have my sincerest wishes your problem has been corrected .......... don't want to see you leave here for an "Orient Express."
Dunbarton "The Middle Aged Kid" '99 XLT SC SB 4x2 4.6 auto 3.55 ls The occasional Z-71 Eater! Wedgewood & Denim, SuperChipped, Airaid FIPK, Rhino Liner, Mobil 1. Man, I got it all! (New Jersey)
Old Nov 7, 1999 | 07:29 PM
Chas's Avatar
Thumbs down
I have the same problem i think. Noticed tranny fluid on the pan a week ago and checked the fluid level. A little down but still in the cross hatch area. Checked today and it didn't register at all. I am starting to really dislike Ford products. Everything from slap happy motors to noisy electronics(ignition, fuel pumps), and dealers that don't have a clue unless it has had a service bulletin for the problem.
98 F150 S/B Reg cab, 4.2 V6, Auto, A/C, Centerlines with Michelin's, Alpine head unit with 6 disc changer, Phoenix Gold M44 amp, JL audio 10" Sub and still adding
