5 Speed Shifter Knobs
Old Sep 28, 1999 | 10:54 PM
DU302's Avatar
Post 5 Speed Shifter *****
My next truck project is to dress up the interior of my truck. One thing is the 5 speed shifter ****. Does anyone know of any place/website that carries some decent looking shifter *****? Also, has anyone taken the factory one off? I took a quick look at it today but didn't get into it. Is it hard to do?
Thanks,
Mike
97 Bright Red, S/C, Off Road XLT, 4.6, 5speed, 3.55 LS.
Sunvisor, Bug shield, Nerf Bars, Leer Cap (for winter), Flowmaster 40 series, Airbox mods, K&N, Eclipse Stereo.
Old Sep 29, 1999 | 09:23 AM
gearjammer's Avatar
Post
I want to get a new one for mine, too. I knicked with something and tore a big chunk out of the top. I tried to twist it off, but it wouldn't budge. I'm not sure if it even comes off that way. If you find out how to get it off, let me know. If you're interested in selling it, I'll be more than happy to take it off your hands. As far as who makes new ones, I can't help you.
1998 F-150 XLT 4x4, Regular Cab, Short-Bed, 4.6L V-8, 5-Speed, 3.55 Rear Gears, Dark Toreador Red
Old Sep 29, 1999 | 06:08 PM
LowDownFord's Avatar
Post
The shifter ***** are glued on and fit like the plastic covers on pliers handles. I have had mine off just pull up very hard and work it back and forth. I have not had any luck with finding an aftermarket piece. An idea though, is to remove the handle and thread the end of the shifter so the aftermarket ones will work.
Old Sep 29, 1999 | 09:59 PM
wildchild's Avatar
Post
i was wondering this too. autozone has some interesting looking replacements. anodized metal or carbon fibre look. not sure of the manufacturer though. i think the price was 17.00 or so.
'97 f150 rc, flair side,4x4,v6,5 spd stock for now...
Old Sep 29, 1999 | 11:31 PM
ShotgunBob's Avatar
Cool
The plastic shifter **** is pressed onto the knurled end of the gear shift, you can pull it off by pulling straight back. I have made an aluminum(you can blacken it to match gear shift using gunsmiths' blackening fluid) extension about 7" long with a 45 degree kink in it so that **** is higher and does not hit the cheap plastic console (or edge of seat) sitting on top of the bench seat. (I know, I need captains chairs.) For you older guys it reminds me of the BiG Daddy Roth model cars. Anyway the **** will pull off. You could make sleeve that can fit over the gear shift then have other end tutnrd down to fit the shift **** of choice. I made my prototype of extension from a piece of plastic grey PVC electrical conduit 45 elbow. It cost .97 and is more than strong enough;I reamed out one end to match gear shift dia, took Brass close pipe nipple and threaded into other end. Used belt sander to knock majority of threads off other end and inserted into the plastic shift ****, secured Elbow to gear shift by hose clamp on proto. On aluminum extension I use two piece split apart set collar, found at ny bearing house.
Maybe I should market these!
Old Sep 29, 1999 | 11:38 PM
DU302's Avatar
Post
Damn, that sounds great ShotgunBob. That's what I may end up doing...fabricating my own. One of those pistol grip shifters off of the old Mopars would look and feel great on these trucks. I always liked them...I may have to try this. Thanks for the homemade idea!
Mike
Old Oct 7, 1999 | 10:14 AM
Henry Ellal's Avatar
Post
DU302. I changed out my shifter **** and it was pretty simple. I took a 12" cresent and
adjusted it to fit under the ****. take a hammer and tap the **** off. The shifter is splined and the o.d. is approx 5/8".
Purchased a Hurst white shifter ball, removed the brass threaded insert, drilled the hole larger and deeper and appliied some adhesive and tapped the ball onto the shifter. I've had the **** installed for about 4 months without a problem.
If I were you I would thread the shifter and tap the ****. this would be a lot cleaner.
99 F-150 XL 4x4. RC Flareside 4.6 5spd, 3.55LS. gibson 3" cat-back, K&N Gen ll.Westin step bars.Ventshade window deflectors and bug deflector and a cool white shifter ball. The SILVER BULLET. Rock and Roll...Baby!!!
Old Oct 7, 1999 | 01:43 PM
DU302's Avatar
Post
Henry, thanks for the help. How does the ball look? I'd like to get a big stainless steel ball if I could...I just don't know where. Maybe I will do the hurst one.
Thanks,
Mike
Lighted Sunvisor, Bug shield, Nerf Bars, Mud Flaps,
Leer Signature Series Cap (for winter), Flowmaster 40 series,
Airbox mods, K&N, Bosch +4's, Complete Eclipse Stereo System.
Old Oct 7, 1999 | 05:24 PM
FLAIRSPORT's Avatar
Talking
I've got a pretty good story about my shifter ****. It wasn't too hard to get off. One time when I was in a hurry to get going, I slammed it from 1st to 2nd and threw the **** right out the rear slider.
1998 F-150 XL flairside 4x4 4.2 5-speed tow pkg. XLT interior except locks/windows
white w/teal&silver graphics
pioneer cd pioneer6x8's
K&N
3.55ls
16" progressive rims
255/75/16 BFG'S
in process of many mods
Old Oct 12, 1999 | 11:52 AM
Post
DU302. The white ball looks great!. You mentioned a stainless steel ball. I know you can buy chrome but stainless?. How big a ball do you want?.
A friend some years back had a hand grenade chromed and He used it for a shifter handle, I though that was pretty different.
Old Oct 12, 1999 | 01:20 PM
DU302's Avatar
Post
Henry...my preference would be for a larger ball. I hate to say it, but the size of the ones on the newer camaro six speeds are awesome...I like that size. I like the billet one in the 35th anniversary mustang. I meant to say billet, not stainless, sorry. I'd just buy that one and adapt it but I want one that is bigger. Any clue at all as to where I might find something like this?
Old Oct 14, 1999 | 11:53 AM
Post
DU302. Hurst makes a large black shifter ball that's the same as the camaro. They also make a nascar fiftieth anniversary
Henry.
Old Oct 21, 1999 | 03:51 PM
Atilla's Avatar
Post
I had a MOMO shift **** on my 97. I had the factory one pulled off and installed the MOMO in seconds. It never slipped or moved in any way. I bought a black leather one that matched the leather steering wheel I installed on the truck. I was very happy with the result and it looked as if it came from the factory
99 F-150 Lariat Supercab Flareside 4x4 (Bright Red), 5.4L, ORP, TTP, Mickey Thompson 34x11.5x17 Baja Belted, SuperChip, K&N Intake System, Borla Dual Catback w/Carbon Fiber Tips, Husky Liners, Captain's Chairs, Factory Six Disc, Clarion EQ320, Fosgate Punch 400x4, Infiniti Kappa separates, JL Audio Stealthbox, Ford Hood Deflector, Spare Tire Lock, Wheel Locks, Passport 7500
[This message has been edited by Atilla (edited 10-21-1999).]
Old Oct 22, 1999 | 09:44 PM
justdriveone's Avatar
Post
Atilla,
Were any modifications needed to install the Momo ****?
Old Oct 4, 2004 | 09:37 AM
eilros's Avatar
Re: 5 Speed Shifter *****
www.ichibahn.com
