Help with installing transmission cooler
I need to know which line is the return line to the transmission, the upper or lower radiator line on a 97 4.6 F150. The tran cooler needs to be in series with the return line so that the fluid go to the radiator first.
97 4.6 F150, 88 5.0 Mustang 1/8 = 7.409 @ 93.72 mph
The return line would have to be the lower. Man should not try to make river (trans fluid) run up hill.
97 F-150, 2WD, Reg Cab,Flareside,Dk Toreador Red, 4.6, 3.55 LS, EGR Bug Deflector, ******* Bed Cover, Bed Liner, XL Full Length Running Boards, Air Aid Kit, Gibson Single Out Cat Back, Superchips, TransGo Shift Kit, Hellwig Rear Sway Bar, Hellwig 2500# Overload Springs
