shift kit?
Old Jul 8, 2002 | 04:22 PM
Rob01F150's Avatar
shift kit?
Could anyone tell where i can find a shift kit for a 4.2L? thx
Old Jul 8, 2002 | 04:40 PM
AjRagno's Avatar
What you're looking for is a shift kit for the Ford AOD-E/4R70W transmission.
Most get a TranGo mechanical shift kit that modifies that valve body. TruckPerformance.com
If you buy the kit and plan to install it yourself, make sure it comes with the video.
There are also kits by Superior Transmission & Level 10.
You should also replace the weak Pressure Regulator Valve & Bypass Clutch Control Valve with Sonnax valves while you have the body out of the transmisison. Baumann Engineering
I'd personally spend extra for a complete valve body that is a simple replacement for the stock one.
LENTECH
Peformance Automatic
