Transfer Case
Old Jun 17, 2002 | 12:12 PM
f-1504x4's Avatar
Transfer Case
I got a quick question, I have a 98 f150 with orp and was wondering what weight to run in the transfer case? Someone told me I should run Mercon ATF trans fluid. Doesnt seem right to me??? Also, If I run the redline in the rear axle..do i still have to add the stuff for the limited slip?
thanks
Justin
Old Jul 10, 2002 | 10:47 AM
relswick's Avatar
I was wondering the same thing and no one seems to have replied to this post yet. The Chilton's catalog for my 98 says the same thing. Should I use the ATF? Do I need to replace this fluid every 25k miles like the rear diff fluid?
Thanks.
Old Jul 10, 2002 | 10:50 AM
jleinweber's Avatar
I'm pretty sure that the transfer case takes 80-90 fluid. I'm not positive, but I don't think I would put ATF in there.
If you have the limited-slip, then yes, you still need to add the friction modifier. Be prepared for heart failure when they tell you how much it will cost for the diff fluid.
Old Jul 10, 2002 | 10:54 AM
relswick's Avatar
I just rebuilt the rear diff. Truck has ~80k on it. I used the 80-90 with friction modifier on the rear and figure I should change the fluid on the front as well, but I haven't found anything yet, other than the Chilton calling out to use the ATF.
I figure the 80-90 would have been what I should be using, which is why I question the Chiltons. Anyone done this yet?
Old Jul 10, 2002 | 05:44 PM
JMC's Avatar
JMC
25 Year Member
The T-CASE on the 97+ F-150s takes ATF.
The rear diff takes 75W140 Synthetic and the front takes 75W90.
I have Amsoil ATF in T-Case. It was drained recently for a clutch job and they put dino oil in it. I have afriend that sells Castrol synthetic ATF and I will try that.
Regards
Jean Marc Chartier
Old Jul 11, 2002 | 10:26 AM
jleinweber's Avatar
JMC is right, I got confused between the TXF case and the front diff.
Hee hee
Old Jul 11, 2002 | 09:41 PM
p_ferlow's Avatar
ATF in the transfer case NOT 80w90!
I just did my rear diff fluid change/cleanup and used Redline 75w90 synthetic. Ford recommends 70w140 but some factory techs have said they get a lot of trucks in with rust and corrosion in the rear axle because the OE synthetic doesn't absorb water.
Anyhow, more than a few sources have told me that you don't need a friction modifier when using Redline diff oil. My rear diff functions as before, no chatter or hop or anything. Friction modifier is usually a fine powdered material that makes the oil more slippery so the clutches in your LS diff don't grab. I got mine at www.mopacauto.com for around $13 a quart and you need just under 3 quarts in the 8.8inch diff. The redline oil is a nice clear golden light brown colour. Stinks like the other gear lubes... I call them "yummy lube" for that reason.
Old Jul 11, 2002 | 10:44 PM
JMC's Avatar
JMC
25 Year Member
I forgot to mention that I did not use friction modifier with the Amsoil 75W140 in my rear diff. So far no problems with chatter or rust??????
Regards
Jean Marc Chartier
