tranny?
Old Apr 20, 2002 | 08:04 PM
4ord_man's Avatar
tranny?
Ok, this is strange, if i put my truck in drive it dies unless i give it gas right when i do it. then when i come to a sudden stop it will die.. But if i stop slowly it wont die. Aslo when it downshifts from 2nd to 1st it kicks down real hard (the whole truck jolts)...
Old Apr 20, 2002 | 09:22 PM
hmustang's Avatar
Sounds like an engine problem as far as it dieing out as far as the hard shift it might be a bad TC.
Old Apr 21, 2002 | 01:07 AM
AjRagno's Avatar
Did you ever get around to checking the tranny filter?????
There's also a TSB for the leaking transmission extention housing seal that you brought up in another message. If you do a search here under "Extention", it is listed.
You could also have a problem with some sort of an air leak in the enigne or intake. Stalling on sudden deceleration is a good indicator of an air leak. Maybe even the IAC valve being stuck. If you have a lot of miles on high octane fuel, it tends to leave a carbon built up in the IAC, EGR & DPFE systems.
Old Apr 30, 2002 | 12:58 PM
4ord_man's Avatar
OK now it doesn't die when it is in drive.. but now i have to floor it just to get the truck moving.. and the tranny vibrates when the rpm's are high.. did the TC go bad???
Old May 7, 2002 | 12:11 AM
4ord_man's Avatar
Tranny is shot, only has reverse...How much for a rebuild?
