Transmission "Thud"
My 2002 Supercrew has developed a sporadic 'thud' in the transmission. It happens immediately when normally accelerating from a stop. Local Ford dealer says they have not heard of any similiar complaints. I do know of at least one other Supercrew owner that experiences the 'thud' 1 out of 10 starts. Any help would be appreciated. The trans shifts fine otherwise.
Are you sure it's in the trans? My 97 F150 SC auto 4.6L 4x4 had a thud noise from a dead stop at about 100,000 miles. It would come and go. Solution: lubricate splines on driveshaft. That took care of the problem. It's back again, but I know what I have to do.
Also, don't believe the dealer when your rear pinion seal starts to leak and they want $350 to replace it. Take it to your local ring & pinion shop and have them do it for $65. Good Luck! Andrew |
Thanks Andrew for your reply. I will check into the driveshaft. The dealer had actually mentioned 'slack' in the driveshaft as one possiblity for the noise. When I pull off from a stop with more speed, I don't notice the 'thud'. It's the gentle starts where it is most noticeable.
My trans. is doing the same on my '01 Supercab. It's about the same frequency as you desribed above but I have notived that is is more prevalent on slight uphills. It seems to be down shifting very hard which sends a "jolt" through the truck. Very annoying.
Also, I have noticed what sounds to me like a "dry bearing squeek" comming from the maunal 4WD shifter, but only at high way speeds. Any experiences with this? I don't think anything is worn since it has 1400 miles on the truck. |
My trans. is doing the same on my '01 Supercab. It's about the same frequency as you desribed above but I have noticed that is is more prevalent on slight uphills. It seems to be down shifting very hard which sends a "jolt" through the truck. Very annoying.
MJD,
I have not had problem with any shifting. Other than the 'thud' on takeoff (which has lessened in the past few days), the trans shifts fine. I plan to still checkout lubing the driveshaft splines and any other driveline adjustments the dealer could checkout. |
I'm having the same problem with my 2002 supercrew. I'm not really sure if it's a 'problem', but I'm going to have it looked at anyway. Hope I find something out, it's just annoying at this point.
I just had the same problem with my 99 4x4 SC. I originally had a worn u-joint. So I replaced it, but didn't lube the splines at the slip yoke before assembling. Well in less than a week I installed a 3in body lift. After installing the body lift, I noticed the 'thud' that you described. Well after countless hours of checking everything involved with the body lift to determine were this 'thud' originated from, I finally released it was the slip yoke at the driveshaft. So I removed the shaft, lubricated with standard greese, reassembled, and no more thud. Easy fix, just wish I would have noticed it before I installed the lift.
kev |
Make sure you put lock tite on those 12 points you take out of the drive shaft. Or, replace them with new ones that already have it on them.
Thud
Ford has a TSB on that problem. The drive shaft needs to be lubed.
Don |
Re: Thud
Originally posted by dnaber Ford has a TSB on that problem. The drive shaft needs to be lubed. Don Kev already said that!!! |
Re: Re: Thud
Originally posted by Eduk8er Kev already said that!!! EXCUSE ME !!!!!:eek: :eek: :eek: I didn't see anyone make mention of the TSB. |
Re: Re: Re: Thud
Originally posted by dnaber EXCUSE ME !!!!!:eek: :eek: :eek: I didn't see anyone make mention of the TSB. |
