Advice on atf flush
Old Jun 24, 2022 | 10:43 PM
Flexibleone's Avatar
Advice on atf flush
2008 4.6 f150 transmission fluid flush ,any advice?
Old Jun 24, 2022 | 11:46 PM
Do not get a flush. Get the fluid exchanged with a machine with no chemicals, using the internal transmission pump to move the fluid, not a pump in the machine. Use Mercon V, not universal fluid. No need to drop the pan unless the fluid is dark or burned, if it is, then drop the pan and change the filter.
