F150
Old Apr 14, 2022 | 01:26 PM
Carpenter42069's Avatar
F150
Which transmission do I have. I have 2001 f150 lariat with the triton 5.4 v8. Is it the 4r70ID1L3PA-JA or the 4r70IDYL3P-LA. How can I tell
Old Apr 14, 2022 | 04:45 PM
projectSHO89's Avatar
Only way to tell is to see if the service tag is still there and legible.
You'll have to crawl under there and look....
Old Apr 14, 2022 | 05:23 PM
is it on the bottom or the top-.of the transmission. I'm trying to order one before pulling this one
Old Apr 14, 2022 | 08:29 PM
If you are facing the tail shaft, it is on the right on the side where the fluid lines come in at...
Good luck.
Old Apr 16, 2022 | 09:25 AM
Good luck.
thank you for your help. One last question are they interchangeable
Old Apr 16, 2022 | 10:10 AM
I'm pretty sure they are interchangeable. However, a 2wd and 4wd transmission is not.
Old Apr 21, 2022 | 04:24 PM
could you tell me about how much the transmission weighs
Old Apr 21, 2022 | 09:45 PM
135 lb plus 35 to 40 lb for the converter. Shipped on a pallet figure 220 lb.
