2005 Ford F150 with a 2004 expedition transmission
Hi I was hoping somebody could help me I have a 2005 Ford F150 4X4 5.4 L and my transmission had no reverse drop the pan drop the valve body Snap in tact ended up getting a transmission for my wrecking yard from 2004 Expedition 4X4 5.4 L and Installed in f-150 an currently going through an issue of the The code p0717 p0715 turbine speed sensor Fault/no signal and a few other codes the expedition had a white plastic cap over the turbine speed sensor port hole When I manually shift 1st to 2nd throttle response is great perfect but when I have it in drive and press on the throttle it bogs out and sputters/vibrates won’t go anywhere it’s almost like a two-stroke where they start out kind of boggy if your not on the pipe and then pick up on speed I have replaced shift solenoids EPC valve solenoid whatever completely overhauled the valve body with new valves and currently still going through the issue of overdrive light blinking as soon as it shifts out of second gear into third The only thing I have not changed is the torque converter please help
I noticed the Ford expedition wiring harness from the transmission to the harness is different from my 2005 Ford F150 can someone please help
