Transmission problem
Old Nov 20, 2020 | 07:44 AM
Carl Warren's Avatar
I have a 2006 F-150 v-6 automatic 2wheel drive it moves forward in reverse and neutral and wont rev up in park
Old Nov 20, 2020 | 10:32 AM
Take it to a transmission shop.
Old Nov 20, 2020 | 11:18 AM
anyone know what may be wrong with it any help would be awesome
Old Nov 20, 2020 | 11:37 AM
Read out the OBD2 with a scanner that can read Ford transmission codes.
Old Nov 20, 2020 | 12:17 PM
projectSHO89's Avatar
Something inside the transmission broke. It's going to need to be pulled and opened up and rebuilt. Probably a clutch has welded itself in the engaged position.
If removal and rebuild isn't in your comfort zone, take it to a shop. I wouldn't even bother trying to read codes, it has an internal mechanical failure.
Old Nov 21, 2020 | 06:57 AM
I apparently have a 4R70E transmission 2 wheel drive with a 4.2 motor do any other year transmission fit this truck
Old Nov 21, 2020 | 09:20 AM
If you want plug and play, you'll want to stay between 2005-2008.
