front seal repair now the tranny wont shift
Old Dec 1, 2019 | 03:38 PM
matt1981's Avatar
Front seal went out on my trans. I changed seal . No more leaks ,but now wont shift on it's own. What did I miss? Need help please
Old Dec 1, 2019 | 04:38 PM
Please list your truck details, we can't see it through the Internet.
Year, engine, transmission model (AOD, 4R70, 4R75, E4OD, 4R100, 6R80)?
Old Dec 1, 2019 | 04:44 PM
matt1981's Avatar
1990 ford f150 351 Cleveland. Not sure of the transmission its automatic . I'm not sure where to find which trans it is.
It shifted fine before I changed seal.
Old Dec 1, 2019 | 04:51 PM
Roadie's Avatar
Just curious. How did you buy the correct seal if you don't know what transmission it is?
Old Dec 1, 2019 | 04:53 PM
matt1981's Avatar
I did put it back together and the torque converter was not positioned all the way inside the trans which left about a half inch in between the bell housing and the engine .I pulled it together .when i did this it locked it up so the flex plate and torque converter would not turn. I pulled it back apart and position it correctly. Hope i didn't damage anything. What about the neutral safety switch . If it's not position correctly could it cause this?
Old Dec 1, 2019 | 05:50 PM
You have either a C6 or E4OD. The C6 is a 3 speed, the E4OD is a 4 speed electronic overdrive with an overdrive lockout switch. This could make a big difference in diagnostics. What is the TRANS code on the door jamb sticker? "K" is C6, "E" is E4OD.
https://www.f150online.com/forums/ar...tion-page.html
If the neutral safety switch is not positioned correctly, it won't start in P or N.
By the way, you don't have a Cleveland unless it's not the original engine, the only 351 in 1990 was the Windsor. If you have a Cleveland, it was swapped, possibly along with the transmission.
Old Dec 1, 2019 | 06:15 PM
matt1981's Avatar
It's the e40d I said Cleveland because that's how its listed at the parts store.
Old Dec 1, 2019 | 08:39 PM
Check all the electrical connections to the transmission.
Old Dec 1, 2019 | 08:49 PM
matt1981's Avatar
I did break the odometer sensor would that affect it?
Old Dec 1, 2019 | 11:18 PM
That would certainly confuse the PCM. Fix it. If it doesn't know how fast you are going, it can't command the transmission properly.
