Overdrive light flashing code P0743
Hey everyone I have a 2002 F150 and I recently had a local shop replace the condenser and compressor for the AC system. Ac works good but as soon as I picked up the truck I was getting a service engine light and the overdrive light was flashing. I thought it was probably just AC related but I checked the codes and I get P0743. The truck seams to run fine, I don't notice any issues with the transmission and I figure it's too much of a coincidence that it happened right after the AC was worked on. The shop owner told me the issues are not related but that he would check it out in a few days when he's not swamped. Any ideas. I figure maybe a short or something wasn't reconnected when working on the AC system. What do you think... coincidence or related? Is there something I can check that would save me from dropping it off at the shop again?
Oh one more thing, I cleared the code and the service engine light comes back on immediately after starting the truck. I don't even have to put it in gear. After about 30 seconds the overdrive light starts flashing.
Oh sorry, I didn't list it. This is what code P0743 says
I checked some fuses but everything seems okay. I originally thought this error code meant my transmission was failing but sounds more electrical in nature. I've been reading and I think most of these parts can be accessed by removing the transmission pan.
P0743 Ford Possible Causes
- Low or dirty transmission fluid
- Wire/circuit issue shorted to power or ground
- Failed torque converter clutch (TCC) solenoid
- Failed TCC assembly in the torque converter
- Failed PCM/ECM/EMC
- Malfunction indicator illumination (check engine light or service engine soon light)
- Stalling when coming to a stop after cruising speeds
- Shudder on take off
- Shudder when coming to a stop
Seems good to me but maybe a transmission fluid change would be a good idea anyways. I think I'll get under the truck and see if the wire harness looks okay. I don't think I want to deal with actually removing the transmission pan though. seems like a mess.
