04_lariat_ben |
02-07-2019 06:47 PM |
Transmission Help
Ive got an 04 F150 Lariat 4x4(new body style) with 115k stock tranny. I have noticed a small ATF leak comming from the inspection port of the bell housing, i believe that it is the seal for the pump. But i have noticed a slight loss in power and shifting, since i would have to remove the transmission to fix the leak im thinking about rebuilding the transmission and installing a shift kit as well. Should i use a performance rebuild kit with the shift kit? And should i buy a new/reman converter? Please add anything that would help with the longevity and performance.
