Overdrive problem
Old Dec 27, 2018 | 02:45 PM
kenhubb's Avatar
Overdrive problem
Hello, this is my first post so bear with me. I have a 1997 F150 with 90K miles on it. My problem is that, this is weird, if I back out of a parking spot or driveway my transmission will not go into overdrive. If I just put it in drive and take off 9 out of 10 times it will go into overdrive. I have noticed if it does not go in OD after backing out I can stop and put it in park and then shift in drive and it will go into OD. I have looked in a lot of places and nowhere I can find anything to let me know what it could be. It is running smooth and shifts very well. Does anybody know what I can look for as the problem?
Thank you very much.
Old Dec 27, 2018 | 02:51 PM
Maybe a wiring issue for the O/D button on the shift stalk? Are you able to twist the handle around?
Old Dec 28, 2018 | 09:12 AM
kenhubb's Avatar
No, it is pretty tight. The light does not come on when I press it though. The light on the instrment cluster does not come on either.
Old Dec 28, 2018 | 09:31 AM
Hmm. I'd try popping it off and checking the switch and the wiring.
Old Dec 28, 2018 | 01:59 PM
kenhubb's Avatar
I will check that when I get a chance. Thanks.
