fordtransmission interchange.
will a 1l3p-bc with id number rff81p7006-aa from a 01 ford 4x4 expedition replace a 5l3p 7000 da with id # rf602p 7006 -a in an 05 f 150 2wd both vehicles have 5.4 tritons
Eh, it might, but you'll probably have to bring over any electronics over from the 05.
If you are willing to wait, there are some folks on here that have much better experience than I do with these types of questions.
2005 vehicle/PCM requires turbine speed sensor (TSS), which the 2001 transmission case is not machine for or have the correct internal parts.
EPC solenoid is different between the 2 transmissions
outputshaft ring gear and speed sensors are different between the 2 transmsisions.
for your application, you need a 2004 - 2007 2wd truck transmission.
