scottfirstf150 |
02-19-2017 06:40 PM |
Moved from az.to calif need transmission help
I have a 2001 super crew 4x4 5.4. it came with a 4r70w that burnt up ,couldn't handle the loads, so I put in a e40d out of a 98 expedition..the only difference in the wireing was everything .so I got the tranny harness out of a 2001 f150 4x4 . now the only difference is,the harness for the 2001 has 2 sensors 1 for speed sensor on the output shaft the other 1 is for the turbine speed..the 98 e40d has only 1 output sensor for the speedo no turbine.i was living in az. at the time and my truck ran on propane so emissions dosent check the computer they run it on the rollers so no spedo wasent a problem ..now I'm trying to regester it in calif. and they don't do rollers and I had to take off my propane (it wasent c.a.r.b. approved.made me go see a referee) he read the comp. no spedo wont let the reddyness test complete .. so what I'm asking is can I wire in the spedo plug to the turbine plug ....or does anybody have any ideas ? I'm pulling my hair out I have 2 weeks left on my temp tag
