Truck won't start after replacing transmission- crank no fire
Old 10-14-2013, 10:29 AM
460 guy's Avatar
98 F150 4x4 auto (20 bolt trans).
Truck ran fine, didn't drive. Found a used trans, swapped it in, now the truck won't fire. adjusted the range sensor/nss and got it to not even crank, put it back and it cranks but still won't spark.
Is there another sensor I don't see? I don't think I missed any plugs, NSS should be in range because it will crank in park but not in Neutral.
Thanks in advance.
Old 10-14-2013, 12:12 PM
glc is offline
20 bolt - I assume you mean a E4OD? Is the TRANS code on your door sticker "E"?
What exact vehicle did the replacement trans come out of?
Old 10-14-2013, 01:50 PM
460 guy's Avatar
Problem solved, Father was trying to help eliminate the AC and had unplugged the CPS. Since I wasn't working up there I didn't think of it.
Quick Reply: Truck won't start after replacing transmission- crank no fire
