Regearing question...i think
So i've been thinking about lifting a 1989 2wd f150 to put some 33" tires on it. I got to thinking about it the other day and it occured to me that that should throw the speedo off, so in order to fix that do I need to regear the tranny? If not, what should be done? I'm kinda new to the whole truck scene (ford scene too for that matter as everything i've every played with was either my dad's vette or my pontiac) Any help is appreciated!
I have a 95 f150 with 36", the lift made the speedo off by about 10 MPH. The real problem is the shift points on the E4OD, I am most likely going to take the lift off. With a older tranny you cant reprogram the shift points, most folks just know how far off the speedo is and drive it as-is.
What tranny you got?
Engine size?
what size lift?
Engine size?
what size lift?
I'll haveta do some digging about the tranny cause I know its been played with, as the truck was used to haul a 5th wheel and I've heard talk about something having been done to it. Its got the 351 engine, and I'm thinking a 4" lift. I guess if there's really not a good way to fix it, I'm kinda curious as to what people do about the speedo issue. Ignore it as you said I guess?
I'm in Ames, IA. But not especially...just not a fan of secondhand parts if ya know what I mean. It's kind of an irrational thought, cause i'm fine with used cars ha. sorry man
