please help:mad:
please help:mad:
hi all i have a 95 ford f150 4x4 it has a new clutch fly wheel slave clyinder and new clutch master and line we bled it and it would not go all the way in gear so i bleed it more but i let the reservoir run out completely now no matter how many times i pump the pedal no fluid comes out of the line and no loss of fluid from the reservoir i saw on YouTube that if you take the rod from inside the cab off fluid dose not come out how can i get fluid back into the new slave with out taking the tranny back off please help
Try reverse bleeding it through the slave bleeder screw. Get one of those hand pump oil cans, fill it with brake fluid, and connect a hose from it to the bleeder. Pump fluid in till it fills up the reservoir.
