Do I need to change Trany oil ?
I love changing my engine oil. I do it every 3000. So I have never changed trany oil. Do I really need to do this ? 89,000 on my trany and it has the shudder problem.
Yea, you've probably decreased the life of that baby about 50%! But you never really know!
I BABY mine! I change the trans fluid EVERY YEAR (25K per year)... I have about 77K on it and started to get the shudder on vacation RIGHT AS MY 75K WARRANTY EXPIRED!!!
I changed the fluid (with only 8K on the fluid) and the fluid was already darkening QUITE A BIT! I replaced the OE Mercon III with Mobil1 Synthetic... WOW! Felt like a tune-up or the vehicle lost about a 1,000 pounds! The shudder is still there but not that noticeable!
I only get the shudder (mostly) between 35-40 MPH.
I recommend changing the filter and FLUSHING the entire system. DO NOT just have the drain and fill done. I also recommend using Mercon V or Amsoil or Mobil1...
BTW: Next truck... Buy a good trans cooler from the start and change the fluids every 2 years or 24K... Your trans should go 200K!
