1995 F150 Clutch problem
I have a 1995 F 150 2WD 5 Speed. The other day I started to here a squeak when I would disengage the clutch but the truck still seemed to drive fine. After a few days I noticed it seemed like I would put it in gear and the truck was struggling to get up to speed. This got to the point where I was in gear and no able to accelerate at all. After parking the truck it will no longer move. I can push the clutch pedal in and it feels like there is less resistance than normal. I can shift the gears with or without the clutch being pushed but the truck will not move at all? Ideas?
Sounds like it's time for a clutch job.
The squeak was probably the throw out bearing. The acceleration issue was the clutch slipping.
You are going to have to get;
1. clutch
2. pressure plate
3. throw out bearing
4. if internal slave cyl-one of those too
5. have the flywheel surfaced
While it's open check your rear main seal on the engine, this is a real good time to change it out if needed.
Good luck
1. clutch
2. pressure plate
Good luck
