What else?
Old Jan 23, 2012 | 12:44 PM
TDAyourdead's Avatar
What else?
I'm getting a tranny flush because I don't know if the previous owner ever had it done. Anything else I should get done while its there and my bank account is positive ? Lol just trying to do preventative work lol
Old Jan 23, 2012 | 01:12 PM
str8t six's Avatar
im guessing you are taking it somewhere to get done, see if they will change the filter too.
how many miles does your truck have?
might want to change the diff fluids, transfer case, fuel fiter, etc.
Old Jan 23, 2012 | 01:26 PM
beechkid's Avatar
25 Year Member
here's what I do....
Engine Management System
• 100,000 Miles Oxygen Sensor Replace
Electronic Fuel Injection System
• Annual Throttle Body & Assembly Inspect, Clean & Lubricate as Necessary
• 6 Months Fuel Injectors Add Redline or BG Brand Fuel Injector Cleaner to
Fuel Tank
• 30,000 Miles Fuel Filter Replace
Fuel Lines
• 5 Years Rubber Replace
Cooling System
• Annual Anode/Cathodic Protection Inspect
• 5 Years Radiator Drain & Flush System
• 5 Years Hoses Replace
Power Steering
• 5 Years Hoses Inspect & Replace as Necessary
• 30,000 Miles Fluid Drain & Refill
Belts
• 4 Years V-Drive Replace
• 5 Years Serpentine Replace
Transmission
• 30,000 Miles Automatic Transmission Fluid Drain & Refill
• 30,000 Miles Automatic Transmission Filter Replace as Necessary
• 30,000 Miles Stick with Automatic Type Fluid Drain & Refill
Differential
Brakes & Assemblies
• Annual Drums, Rotors & Linings Surface Sand, Degrease, Inspect & Replace as
Necessary
• Annual Fluid- Silicone Type Bleed System
• 3 Years Fluid- Conventional Type Bleed System
• 30,000 Miles Wheel Bearings Inspect, Clean & Repack
Wheels/Tires
• 6 Months Tires Rotate, Inspect & Adjust Pressure
Old Jan 23, 2012 | 01:28 PM
It's got 107000 the rear diff is also getting changed because the old one is is rusted lol.. Thanks guys
