transmission 11 codes problem
Old Oct 4, 2011 | 08:55 PM
jaywalleye's Avatar
my wifes truck is a 2000 f150. last week she went to leave and it would not move. o/d light was flashing. hooked up to a code reader and got these codes. p0750 p0755 p0743 p0443 p1451 p0135 p0155 p1409 p0141 p0161. ya thats alot of them eh! went to 2 shops one guy said its in lymph mode. the other said its the whole brain. help i,m so lost. thanks 2000 f150 2wd 4.6
Old Oct 4, 2011 | 09:17 PM
projectSHO89's Avatar
Blown fuse.
Old Oct 5, 2011 | 07:16 PM
jaywalleye's Avatar
fuses and relays all good!
Old Oct 5, 2011 | 07:27 PM
Fuses checked with a meter?
I've heard of this when a major harness connector through the firewall is loose or corroded.
Old Oct 5, 2011 | 07:35 PM
jaywalleye's Avatar
no with a fuse tester. took them all out for visual and a test. in cab and under hood. i did just find out that someone fixed the power windows (motor). the day before..if it could some how be related.. stumped..
Old Oct 5, 2011 | 07:39 PM
jaywalleye's Avatar
also got these codes again p1409 p0155 p0135 p1451 p0443 p0743 p0755 p1747 and o/d light flashing
Old Oct 5, 2011 | 09:09 PM
All of your codes have one component in common: Fuse F23 in the BJB. If the fuse is good, the circuit is not.
Old Oct 5, 2011 | 09:41 PM
jaywalleye's Avatar
and any advice on fixing the circuit? is it a board or harness. or a headache and i should bring it in to a shop?
