Rear Gear Ratio?
If you haven't doinked with the rear end and it is stock, just look on the door jamb sticker under axle code. Then post it back here and someone will let you know.
Now if the gearing has been changed you count the teeth on the pinion gear and divide it into the number of teeth on the ring gear. But you gotta remove the cover to do it that way.
i dont understand why they put a open differential in a FX2 i thought those were suppose to come with limited slips.
i just thought the FX2 was like the FX4 package just a 2WD version. and all the fx4s came with limited slips or trac lok as ford calls it. so i would have thought the FX2 came with one but i guess not.
No all FX4s did not come with a LS.
