trans temp gauge
Old Jul 27, 2011 | 02:20 PM
FF301's Avatar
trans temp gauge
ok - i see a lot of threads about trans temps, how or where did you install the sensor unit.
i have an electronic pick up unit
Old Jul 27, 2011 | 05:37 PM
grizzstang's Avatar
The best place IMO is the transmission output line. You would see the hottest temps there.
Old Jul 27, 2011 | 06:34 PM
camopaint0707's Avatar
Yeah right before the trans cooler
Old Jul 27, 2011 | 11:58 PM
FF301's Avatar
witch line is the output to the cooler, and whats the best way to connect in? can i cut tubing and use compression fitiings _ what size? what kind of pressure's are there ?
Old Jul 28, 2011 | 02:38 PM
grizzstang's Avatar
The trans output line is the one that runs into the top of your rad cooler, it then comes out the bottom of the rad cooler and goes to your external cooler then back to the trans.
You can cut the tubing and use compression fittings. I cut mine right before it went into the rad cooler (to keep it in the engine compartment as apposed to under the truck). I used a simple T fitting and some rubber transmission line and hose clamps.
I am not sure of the line size it has been a while since I did it.
Old Jul 28, 2011 | 10:25 PM
adrianspeeder's Avatar
Follow the lines and fluid comes from the front of the trans, and returns at the rear.
Adrianspeeder
Old Jul 28, 2011 | 11:24 PM
FF301's Avatar
thanks guys, will be looking into this on fri - (i work midnights so a nap will be first)
also gotta pick a spot for the temp gauge
Old Jul 29, 2011 | 01:05 AM
So I can just put a T-fitting onto the trans line and put my sender into the line and I should be good to go?
Old Jul 29, 2011 | 02:44 AM
fairlaner's Avatar
The lines are 3/8" OD on my '99. I used Autometer's manifold, but you can also use fittings available at any hardware store.
Trans temp sensor mounted on trans output line ...
Old Jul 29, 2011 | 02:53 AM
Oh snap that picture is perfect. Thanks. Can I use anywhere on the trans lines? Like can I use a spot right beside the trans cooler?
Old Jul 31, 2011 | 12:21 PM
Just make sure it is before the cooler.
Adrianspeeder
Old Aug 2, 2011 | 01:48 AM
Fifty150's Avatar
Install 3 gauges. One in the cooling line to see how hot the fluid is coming out. One in the return line to see the temp of fluid going back, and to check on the efficiency of your cooling units. Then finally, a sensor in your pan to check pan temperature.
Old Aug 2, 2011 | 03:24 AM
rancheroracer's Avatar
If your sending unit is 1/8" npt a lot of the Ford trans. have an 1/8" npt plug near the trans shift lever. That's where I put mine on my '05 & it worked fine.
Old Aug 2, 2011 | 04:12 AM
3 trans temp gauges might be excessive.
Old Aug 2, 2011 | 11:57 AM
One could wire a couple of senders thru a 2-way toggle if that was desired although the one in the transmission would show the oil temp in the transmission. Cooler out line would show temp from converter which is hotter, might scare you to see how hot that gets.
