Transmission question
Old Jul 20, 2011 | 02:41 AM
ibf150's Avatar
To start off my truck is a 2005 F150 XLT supercrew 4X4 with the 5.4L and it has 106k miles on it. The differentials are equipped with the 3.55LS and I'm looking at a lift and 35 inch tires. There is no doubt in my mind that I need to re-gear and plan on going with 4.56s but the amount of cash on hand is limited.
If I use the edge evo to program for 35" tires will my transmission still constantly be shifting up and down and going in and out of overdrive?
Or would I be better off doing the lift and gears first and waiting to get the 35s since the 32s I have are still in great shape?
Thank you in advance
-Ivan
Old Jul 20, 2011 | 02:48 AM
camopaint0707's Avatar
I have a 2004 5.4 with a 2 inch lift and 35 inch nitto's and regeared it using a hypertech programmer and have not had any tranmission problems.
Old Jul 20, 2011 | 04:26 AM
It should be fine with reprogramming till you can afford gears. If it constantly shifts up and down and in and out of overdrive, turn overdrive off.
Old Jul 20, 2011 | 09:11 PM
ibf150's Avatar
35s and the lift kit first then!
