Transmission ID
Old Jul 8, 2011 | 10:00 AM
markle's Avatar
Transmission ID
Well, I have a 2004 F150 5.4 w/ the 4r75w I think (transmission code B) and you guessed it the O/D just went out last Saturday. So, I started to work on it all the normal was true, partial broken snap ring (still in place). I am 99% sure I got all of the old parts out of the VB and removed the O/D servo. Replace with same since it looked okay, but forgot to check if the band was in place :-( But I figured that since the servo was never "loose" it should have not been any different (Was this a wrong assumption?) Now it is back together and has no engine braking in 2nd, so I know the O/D band is working. All this is with the O/D switched off.
So my real question is if I pick up a used transmission from the junk yard, what is the easiest way to tell it is a 4r75w or e compared to a 4r70? Do they each have a 14 bolt gasket, part number, etc? I have searched this forum up and down and could seem to find the answer to this. Thanks in advance!
Old Jul 8, 2011 | 10:15 AM
Gotts2BMe's Avatar
you have to put it in hard 2nd (2nd on your indicator) and try it.
They all have the same pan. 4r70e 01-06 (I think 06) 4.6 and 01-03 5.4. 4r75w 04-05 5.4. 4r75e 06-08 5.4
Old Jul 8, 2011 | 11:23 AM
markle's Avatar
Thanks for the reply Gotts!
Yup, stuck the lever on the big 2 and nothing but coasting @ 40 mph after I left off the gas. But, it does rev and then try to slip into 3rd with O/D on...
I was afraid that all the cases look the same, the yard down the street from me has a ton of the transmissions to use to swap/rebuild/etc for $450 but I just want to make sure I pick one up that will be plug and play, till I get this one fixed.
Old Jul 8, 2011 | 04:14 PM
Gotts2BMe's Avatar
This is the ID you are looking for...
ID 3L3P-LA
I believe it is on the passenger side if memory serves me correctly
