4wd engagement problem
Old May 11, 2011 | 03:21 PM
anynamewilldo's Avatar
Vehicle
2001 F150 Supercrew 5.4l 4wd
Issue
When I turn the switch to 4wd high, I get a loud and rapid grinding noise. It isn't a kachunk grind like from a manual transmission but a very fast/rapid grind or clicking noise that will stop if I turn the switch back to 2wd.
Once I slow down to a stop the truck will engage into 4wd.
What do you guys think is the problem??
Any help/suggestions is most appreciated, thanks.
Old May 11, 2011 | 10:09 PM
steven'sf1504x4's Avatar
check the fluid level in the transfer case.
Old Nov 3, 2011 | 05:08 PM
I am bumping this back up.
I took the truck to the Ford dealer, they say everything checks out, the problem is the transfer case itself, new one/rebuild needed.
The 4wd still works just fine as long as you switch into 4wd while stopped.
When switching into 4wd while moving you get a very high pitch grind most of the time. Some times it will work, but not too often.
I picked up the truck, not sure what to do.
Any suggestions??????
Old Nov 3, 2011 | 05:16 PM
It could be a worn shift fork or something else.....best bet would be to find a replacement at a salvage yard....
