trans fault light with O/D light blinking
Old Apr 21, 2011 | 07:39 PM
ivrodriguezfx4's Avatar
Hi guys i drive a 2007 screw fx4, i am having this issue since a week ago. truck runnig fine however when that happens the truck feels sluggish.
Any help will apreciatted.
Old Apr 21, 2011 | 09:06 PM
projectSHO89's Avatar
Get the fault codes scanned.
Old Apr 22, 2011 | 11:32 PM
jakek88's Avatar
what he said^^^ i just got my truck back from ford, it was doing the same thing. i had a burnt clutch in the transmission. no 1st or over drive. what where you doing when it started acting up? pulling, mudding, or just driving?
Old Apr 24, 2011 | 12:58 AM
BlueOvalFitter's Avatar
Thumbs up
I had the same problem.Ford replaced a shift solenoid and wire harness in the tranny.
Old Apr 24, 2011 | 01:02 AM
camopaint0707's Avatar
How many miles?
Old Apr 24, 2011 | 01:06 AM
Originally Posted by camopaint0707
How many miles?
75K miles.I have 79K on it now.
Old Apr 24, 2011 | 07:56 AM
Once I had a headache. I took some aspirin and I felt better later. About as relevant. It is IMPOSSIBLE to remotely diagnose a transmission fault based on a single experience and zero data.... your particular experience is probably not relevant except by coincidence.
There are numerous electrical components and dozens of mechanical parts that can cause a flashing O/D light. Unless someone gathers information and performs some type of diagnosis, you might as well fart into a hurricane.
Old Apr 24, 2011 | 09:06 AM
NCSU_05_FX4's Avatar
Happened to mine, lost 1st and R for a day, then there was a loud clunk and everything started working again. Less then 500 miles later I had to replace the transmission when after losing 3rd and OD.
Shrot answer is, get it checked out soon.
- NCSU
Old Apr 24, 2011 | 02:11 PM
Cool
I "NOW" have a headache after reading your response!
Old May 4, 2011 | 12:47 PM
Thanks guys for your replys sorry took forever to respond i found out what is causing the light, looked under the truck and is leaking oil, so truck is in the shop now.
Old May 5, 2011 | 05:20 PM
Question
Update?
Old Jul 17, 2011 | 11:23 PM
Courtney's Avatar
Took mine {2006, 5.4, SC) in for this Thursday. Both low and OD out. $3,000 for the transmission brings the total to just shy of $7,000 in the last 90 days,
It's going on the block the moment I get it back.
