Which axles do I have? What gears to get?
Old Mar 24, 2011 | 08:43 PM
MossyOak3006's Avatar
I have a 2006 F-150 XLT Crewcab 4X4 with 5.4 V8. I'm thinking about yukon 4.56 gears because I'm going to get a lift and 35's. I have 3.55 gears now and I know I need to regear. I just want to know exactly which gears to get? Which ones are compatable with my axles? What's the exact part (like 9" 31 spline or what)? My truck is all stock now
Old Mar 25, 2011 | 08:42 AM
verifine-f-150's Avatar
Check your door for your axle code, for example mine is H9 which means 3.55 gears with limited slip.
Old Mar 25, 2011 | 08:48 AM
kingfish51's Avatar
Your rear axle is a 9.75" and the front is an 8.8" reverse cut.
Old Mar 25, 2011 | 10:49 AM
And how many spline are they?
Old Mar 25, 2011 | 12:11 PM
kingfish51's Avatar
Not sure, but I think 31. Someone will probably be along to verify. Might do a search on "spline".
Old Mar 25, 2011 | 12:34 PM
str8t six's Avatar
34 spline is for the rear.
i got my gears from wayne at diffsonly.com give him a call and he can get you what you need.
Old Mar 25, 2011 | 03:23 PM
1whitelightning's Avatar
wayne at diffsonly.com never knows what he is talking about. i called him about gearing recommendations for my 35's and he told me 5.13's should give me about 2100 rpm at highway speeds. i cant believe anyone would take his advice or make a purchase from him. str8tsix id consider getting your **** checked out or sending your junk back right away.
Old Mar 25, 2011 | 03:27 PM
Old Mar 25, 2011 | 03:54 PM
2003f150cruzer's Avatar
actually, the 34 spline axles came in the 04-05. In 06 they changed to the 35 spline.
Old Mar 25, 2011 | 04:54 PM
str8t six's Avatar
well i guess ill find out if he shipped me the right gears when i get them put in. i didnt take his advice, i already knew what i wanted to run and those rpms would definitely be higher with 5.13's.
Old Mar 25, 2011 | 06:59 PM
TheDesertRat's Avatar
5.13's would be ideal.................for 37"+ tires........
Old Mar 26, 2011 | 04:40 AM
Even with tires that big, a 5.4 doesn't need 5.13's unless you are building a dedicated offroader. Not too practical for the street or a DD.
With 35's and 4.56's, your rpm's in OD at 70 would be 2150. With 35's and 5.13's, at 2100 rpm you would only be doing 60.
