4x4 low and overdrive
Old Jan 27, 2011 | 10:08 PM
camopaint0707's Avatar
On my 2004 F150 fx4, whenever I push the overdrive button on the shifter nothing happens. No light comes on and it makes no difference. What can I check to see if it is broken or not? Also how do I engage 4x4 low? On both of my F150's the 4x4 low does not engage. 4x4 high does but not the low option. Both are electronic switches.
Old Jan 28, 2011 | 01:02 AM
anyone?
Old Jan 28, 2011 | 02:30 AM
wifordx4's Avatar
You need to have the truck in park to enter 4low
Old Jan 28, 2011 | 07:16 AM
kingfish51's Avatar
Or neutral, stopped with foot on the brake.
Old Jan 28, 2011 | 09:09 AM
PickledPolak's Avatar
Your TCS switch in the shifter is likely hooped. Cheap part and easy to replace. All that switch does is command the PCM to inhibit a 3-4 upshift. Later models that would be a tow/haul switch. Cheers!
Old Jan 28, 2011 | 09:14 AM
Have you checked all the fuses?
Old Jan 29, 2011 | 03:49 PM
Wow thank you guys. I never knew that. Thank you very much.
Old Jan 29, 2011 | 04:25 PM
kingfish51's Avatar
It is listed in the owners manual. If you do not have one, you can download one for free from www.motorcraftservice.com.
Old Jan 29, 2011 | 04:30 PM
No both of my F150s were bought used and I seldom ever used the 4x4 low so I didn't realize that it engages differently than 4x4 hi.
