help 4x4 problem!
Old Dec 4, 2010 | 07:32 PM
marcusjb's Avatar
help 4x4 problem!
Ok, I've had this truck for about 30k miles. I believe it has had this problem since I bought it with 30k miles on it. 04 F150 acts like it's binding when in 4x4 on any road conditions driving in a straight line. I'm used to them binding a bit on hard surfaces in a turn but this thing does it going straight down the road in the snow. It feels like the front slips just a little every once in a while. I had to think of gear ratio, that's what it feels like, but I did a test. I jacked up one side and ran it in 4x4 for a while with a paint stripe on the spinning front and rear tire. I can see no difference in the ratio, and everything works smoothly on the jacks. Any ideas?
Old Dec 4, 2010 | 07:58 PM
masseyman's Avatar
Are the tires all basically the same size?
Old Dec 4, 2010 | 08:03 PM
marcusjb's Avatar
Yep, all identical Michelins
Old Dec 18, 2010 | 02:41 PM
marcusjb's Avatar
Ok, I'm an idiot. They are NOT identical tires. They were sold to me as a set of matched tires by the local Les Schwab, but on closer inspection, two of them are 265/70 17's and two are 245/70 17's. Problem solved.
