1977 C6 Questons
Old Sep 21, 2010 | 11:26 AM
Elk Ears's Avatar
1977 C6 Questons
I'm confused about which ATF to use. I've been putting Dex/Merc in it, but should I use Type F?
And I need to remove the pan, beat out a dent, and replace it with new gasket. How much fluid will it need, without draining the torque converter?
thanks,
Moose
Old Sep 21, 2010 | 02:56 PM
grizzstang's Avatar
66-76 = Type F
77-96 = Mercon
But really you can run either of them. The story goes that the Mercon was used to make for smoother shifts. I run Type F in my 79 C4 and I would think that most high performance applications of these transmissions would run Type F.
Old Sep 22, 2010 | 02:24 PM
It takes Mercon and the pan holds 6 quarts.
Old Sep 27, 2010 | 11:08 AM
Elk Ears's Avatar
Thanks.
