Transfer case shift lever
Old Sep 10, 2010 | 12:48 PM
aklauncher57's Avatar
I replaced my transfer case on my 1994 f150 manual shift the transfer case came from a 1997 f150 borg warner the lever on the new case does not line up with the old shift lever. old shift lever was staight up in 2high and new lever is on an angele . Drilled new hole for the shift does not go in to 4 low verey easy is there a new shift lever i can use or a used part from another shift to make it work better.
