transmission float
Old Aug 23, 2010 | 07:29 AM
jconna's Avatar
transmission float
How far should my truck float when in gear? I was pulling a pontoon boat back from VA around 4 months ago and I heard a bang/clunk 3 different times. This happened at highway speed and always when I was in the process of letting off the gas.
It seems to run fine since and I don't notice any slipping between gears so I've just been keeping an eye on it but it seems to me like I'm getting more float on grades when in gear than I used to. Sometimes it seems even when on very little grade.
Yesterday though I got a little more concerned. Granted I was on a bit of a grade (20-30%) but while in reverse I left off the brake planning to back up a little farther and it coasted forward 6 feet or so about as fast as it would have done in neutral. Maybe I'm just being paranoid but is that normal?
Old Aug 23, 2010 | 09:42 PM
jgger's Avatar
First check the U joints.
Next check the hitch/ball for tightness.
Then make sure you were using the proper size ball.
Old Aug 31, 2010 | 02:35 PM
jconna's Avatar
Sorry jgger....I missed this update somehow. The 2nd two are definitely OK but I can't say on the U joints. Wouldn't even know what to look for. I'll do some searches on it but it's going in for inspection tomorrow so I'm guessing I'm going to find out.
