2004 F-150 Shift lever
Old Aug 6, 2010 | 03:28 PM
fourwinns's Avatar
This is an inttermittent problem but getting worse. When I push the brake pedal down and then squeeze the shifter lever button to engage it, it is stuck and will not let me shift into drive. I have to cycle the brake pedal and squeeze the shift lever button at the same time to get it to work. Would appreciate some help.
Old Aug 6, 2010 | 03:47 PM
Check your brake light switch.
Old Aug 6, 2010 | 04:20 PM
fourwinns's Avatar
So if the brake light switch does not work it will not release the shift lever.
Old Aug 6, 2010 | 07:26 PM
Correct. That's why it's called a brake interlock.
