AOD wiring ? have a 5 wireplug?
I have a aod I want to put in a f-150 behind a 4bt cummins. I have searched the web and cant find out what and why my trans has a nss plug with 5 wires? does anybody know and what the color-code is?
Giving up on AOD... I got the 4bt with flywheel and small-block adapter so I am having the local yard pull me a 4 plus od stick with the pre-modular small-block bell 87 to 93? Are these transmissions any good? Then I picked up the pedal set from a pull-it yard. Hopefully the clutch master will adapt. probably will have to make a drive shaft. trans mounts, what else? Thanks
