M5R2 shift fork replacement
Old Apr 14, 2010 | 02:38 PM
charkar's Avatar
First I would like to say hello to everyone, I am new to the forum.
I had my 1 - 2 shift fork shear clean, and the 3 - 4 is almost gone, so I ordered both.
What I am looking for is some directions, and a diagram about how to replace the forks.
I also ordered replacement caps as well.
Also, does anyone have an idea how to do a clean flush to get the old fluid out since I assume it is loaded with shavings. I bought the truck a year ago, and I doubt anyone ever changed the fluid anyway.
What would be the best fluid to use? Heard B&M Slick Shift was pretty good. Any other ideas?
I have been doing a lot of work on this truck, already replaced the engine just months after I bought the truck, the pinion gear went, I was going to rebuild the axle, however, it wallowed out the hole, so I replaced it with another old axle, but still have the new ring, and pinion gear, I will probably get around to working on that in time.
Also, when driving, I feel a lot of vibration though the shifter, not sure if the U joints need replaced, I know how to replace all but the ones on the front axle, looks like one tough job. lol
Well, for now, just want to figure out the shift fork job.
Thank you,
Charles
Old Apr 14, 2010 | 04:43 PM
Any ATF that meets Mercon V specs is fine for a M5.
Old Apr 15, 2010 | 09:47 AM
charkar's Avatar
Thank you
Thank you for that info, just wanted to make sure what to put in.
Old Apr 17, 2010 | 09:06 PM
jtownsend's Avatar
i just had the same thing happen to me, i took the tranny out and took it to aamco, they rebuilt the entire shift tower for 400. guy who did it says he didnt know why mine had aluminum shift forks, guess the 4.6 had cast ones, wierd, yeas good luck rebuilding it man
