Once and for all: Fluid Change Intervals
Old Apr 6, 2010 | 09:11 AM
CUPID's Avatar
Question Once and for all: Fluid Change Intervals
I've been surfing through here for an hour to find the answer to this question:
When should I change my transmission fluid and transfer case fluid?
I have a 2007, 4x4 Lariat. The book has convoluted instructions at the 30K mile mark and the 60K mile mark.
Please discuss.
Old Apr 6, 2010 | 11:06 AM
38Chevy454's Avatar
A lot depends on your usage. Towing, heavy hauling, or similar will make your trans run hotter and under more load with increased potential wear. Therefore shorter interval is best. A good cooler also helps if you have hard usage.
Changing earlier will never hurt anything. Besides money for the extra trans fluid and filters.
On my 97 Expedition 4x4, I welded a drain plug on the trans so I can drain the pan without the usual mess. I change the fluid every 30K, but the filter only every other time. I don't do the whole system flush thing. My opinion is keep the fluid clean and fresher and your trans will stay working good. I also don't do any serious towing with the Expedition beyond a small utility trailer, I have a 1-ton dually for heavy towing.
Old Apr 6, 2010 | 07:57 PM
MitchF150's Avatar
I added a drain plug to my pan as well and now I just drain the pan and fill with fresh fluid. Nothing fancy, just the 'supertech' mercon stuff they have at Walmart by the gallon.. I need 6 qts to do a pan drain/refill.
I do this about every second oil change or at least once a year. Been doing just the pan drops since I did do a full fluid change when I first got the truck in 2001. I've only had the drain plug for about 2 years now, so I've not done a filter change yet, but that'll be done on the next change..
Might be overkill, but it's cheap and my fluid is nice and clear and red and I tow a #5000 TT about 5-6 times a year and it's my daily driver.
Just what I do....
Mitch
Old Apr 7, 2010 | 01:26 AM
Fifty150's Avatar
Consider upgrading to Mag Hytec pans & covers. I have an '07 like you. I have been draining the pan every 10,000 miles. The peace of mind comes from watching reasonable clean fluid come out. I know that I do it often enough that I don't have to worry about driving around with burnt transmission fluid.
Old Apr 7, 2010 | 09:03 PM
Roadie's Avatar
Just what I do....
Mitch
I'm sure you know that the torque converter on your model has a drain plug. You can drain almost all of it at the same time.
Old Apr 8, 2010 | 01:40 AM
MitchF150's Avatar
Why? I did that already... No need to keep doing it and it's really a PITA to do.. With my yearly pan drops it's been keeping the fluid very fresh and clean and there is never anything on the magnet?
Mitch
Old Apr 8, 2010 | 01:43 AM
illness95's Avatar
NEVER !!!! lmao
Old Apr 8, 2010 | 02:10 AM
MitchF150's Avatar
yep... NEVER!
Old Apr 8, 2010 | 11:48 AM
grizzstang's Avatar
Changing the trans more than every 50,000 km or 30,000 miles is overkill IMO, unless you have overheated the trans and burnt your fluid.
Adding a trans temp gauge (and a cooler if your 04 doesn't have the tow package) would be good idea if you tow anything or haul very heavy loads.
I don't know what the manual says but I only do transfer cases every 100,000 km or about 60,000 miles. I just did the girlfriends Blazer for the first time at 130,000 km or about 80,000 miles and it was not too dirty. Honestly I expected it to be pretty nasty because she will put it in 4 wheel drive if someone walks by with an ice cream cone.
Old Apr 8, 2010 | 11:52 AM
illness95's Avatar
Adding a stand alone cooler is the BEST thing u can do for an auto trans...
Old Apr 8, 2010 | 12:22 PM
Transfer case and diffs should be done every 100k miles, that's plenty often enough. If I had an automatic, I'd be doing it every 30k, complete exchange, unless I had Amsoil fluid. That stuff I'd run 60k.
Old Apr 9, 2010 | 12:52 PM
Fifty150's Avatar
Originally Posted by grizzstang
I just did the girlfriends Blazer.
She drives a Chevy?
Dump Her!
Old May 8, 2010 | 09:20 AM
TNoff's Avatar
looking to change fluids. decent info here.
Old May 15, 2010 | 07:49 AM
a930rocket's Avatar
So without starting another thread, what's the procedure to swap the fluid in the auto trans in an 01? I can figure out the pan and filter I'm sure, but what about the converter? Does it have a drain plug? How do I swap all the fluid or the majority of it?
The dealer wants $183 + tax. The quick lube place wants $130. I figure I can do it cheaper...
BTW: Where did you guys get the weld on drain plugs and exactly where did you install them on the pan?
Old May 15, 2010 | 11:03 AM
A complete change takes 14 quarts of fluid - that makes the $130 not look so bad.
Not sure whether an 01 still has a converter drain. To find out, crawl under and drop the inspection cover and have someone turn the engine over with a socket and breaker bar and look for one.
