Transmission Swap
You'll need a new computer, wiring harness, Flex plate, Torque convertor and of course correct transmission with attached speed sensors and such. Its doable, but not much point or gain. If you want a Auto bad enough, you may look into getting a different truck. Unless you have time and a donor vehicle with the auto in it then its not so bad, just time consuming.
Not necessarily, depending what you are trying to do. But generally it is a complex conversion, and if it is your primary vehicle then its a bad idea to immobilize it while you juggle work, life and the swap all at once.
