would I have to regear
Did you ever find out what gears you are currently running? If you have 3.73 I think you would be "ok" for a while, if you have 3.55 I would stick with 33" or go ahead and regear when you get 35's.
Open your driver's side door and there will be a white sticker there. Find the word axle and then right under the word axle will be a letter with a number. Ex H9 is the 3.55ls. Find that and post it here and we can tell you what you have. As for running 35's, If i had the 3.73's i would try it and decide from there but if you have 3.55's it's just not really pratical. It won't hurt anything if you do for a little while but i would just wait and get tires and re-gear at the same time.
I have accually been looking at 4.56 gears would those work ok?
Also do I get the gears for the 8.8 or 9.0?
I am guessing the 8.8
You should try to match the final drive ratio as close to stock as possible. Being too "tall" is never a good idea. Being too "short" will give you better performance but worse gas mileage but is not harmful. I went from stock 29.5" with 3.55 to 33" with 4.10 and that was almost a perfect match to stock. There are many online calculators that can help you select the proper gearing for your tire size. Don't cheap out...do it right.
