another thread about swapping 4R100
Old May 1, 2009 | 10:54 PM
2low2slow's Avatar
I've got a question, wanted to see what you guys thought: I'm about to swap in a lightning blower onto my 2001 5.4. I don't feel like blowing up my stock trans so I'm looking at options to replace or rebuild it.
So I've been talkin to this guy on NLOC regarding a built 4R100 he has. He said he has a driveshaft, crossmember, and converter that he could put together as a package. Does this seem like a viable option? It's absolutely not possible to tune my computer to work with this setup? another guy on NLOC might have a comp off a wrecked L, but would that drive the costs way up? I'm trying to stay under 2k for parts. Let me hear your opinions por favor
Old May 1, 2009 | 11:04 PM
Skaz's Avatar
You will need the lightning PCM to run the 4R100.
Old May 2, 2009 | 12:35 AM
2low2slow's Avatar
How much would a lightning PCM run, new and used? if i could get one, would this be the best way to go, or could I just have my 4R70 built up. I'm probably only going to be around the mid 300's hp wise.
Old May 2, 2009 | 01:17 AM
Klitch's Avatar
my honest suggestion, read my sig. do your research thoroughly, i wish i met Darrin first.
Old May 2, 2009 | 01:38 AM
2low2slow's Avatar
Thanks Klitch, I've been trying to read your thread off and on all day (couldn't sit still for the whole thing ), looks like you had a tough time of it. Looks like everything worked out in the end? Did you send your tranny to Darrin to be rebuilt? what is the cost involved in such a case?
the 4R100 is such a tantalizing option, hard to let go, maybe its time tho.
Old May 2, 2009 | 02:51 AM
minimonster17's Avatar
the 4R100 swap requires other things as well, including driveshaft modifications, exhaust crossover modifications, the pcm MUST be changed out, flywheel modifications, etc. not a "budget" swap. a built trans, 4R100 or 4R70W is something you want to do right the first time. No cutting corners, or you'll be sorry.
Old May 2, 2009 | 09:28 AM
Klitch's Avatar
the 4r100 swap is only financially feasible if your putting down real heavy numbers in the first place. for the range you and i fall in, the 4r70w is definitely the way to go if you have it built by someone who knows what they are doing. i dont want to answer your question about price, i feel thats best left up to you and Darrin if you talk to him. i will say his price before shipping will be closer to the 3 mark, but dont let that run you off, you dont want to chance it and have the problem i did.
i wound up getting another trans from Darrin, im still trying to get my money back from Rods cars, I have small claims on the 22nd this month with him and have the judge affirm the arbitration agreement and arbitration decision.
you couldnt sit still? lol! think of how i felt lmao
Old May 2, 2009 | 11:01 AM
phil6608's Avatar
Like Klitch said,at your power level.Even if you later go up to 400RWHP, a good built 4r70 or 4r75 should handle the power.
The only reason I went with a 4r100 is my truck is 6000LBs and I was going through built 4r70 trannys every year. After 3 I decided I had to have something stronger.
And just so you know what it cost me.Built 4r100= 5K. parts and laber=3K!
Phil
Old May 2, 2009 | 12:47 PM
2low2slow's Avatar
ahhh, good advice Klitch and Phil. I'll probably be looking for a good local trans builder then.
Good luck with your legal issue Klitch, nail that guy's @$$ to the wall
Old May 2, 2009 | 07:26 PM
Klitch's Avatar
man be weary of the local guys. i tried to trust one, come to find out i ran into 2 bad businesses in 1 shot.
dont worry, i plan to get him to pay me back one way or another. i also plan on making it much more public once i get my money back.
