Slip Clutches
Old Apr 6, 2009 | 12:41 AM
mcintosh8822's Avatar
Slip Clutches
i have a 2004 f150 4x4 and i was driving my buddy in it to show him the weird rattling ive been having in the front end when i put the truck in 4 wheel drive. he said its that the slip clutches are stuck because i dont ever use the 4 wheel drive. could this be my porblem? if so how do i fix it?:
Old Apr 6, 2009 | 01:17 AM
Paralyzer's Avatar
He has no idea what he is talkin about....there are NO clutches in the T-cases of these trucks unless you have an AWD Harley or Limited.
Old Apr 6, 2009 | 01:42 AM
so the front end is a locking deferential? and the tires are going to spin the same speed no matter what? which is the cause of front end rattle?
Old Apr 6, 2009 | 02:02 AM
Paralyzer's Avatar
the front axle is an open diff, no locker, no clutches. Almost all noises in the front axle of these trucks are caused by an IWE not fully engaging/disengaging.
Old Apr 6, 2009 | 02:10 AM
so basically its fine just hasnt been run in a while?
Old Apr 6, 2009 | 01:39 PM
chiefFX4's Avatar
no. check for vacuum leaks. if you look on the passenger side of the firewall you will see 2 solenoids. those control your 4wd. start there.
