1st-2nd harsh
Old Feb 18, 2009 | 04:41 PM
blueoval5.4's Avatar
1st-2nd harsh
i have a 05 f150 5.4 with 60,000 miles and most of the time it shifts hard into 2nd gear. it seems to be intermittent. i had trans flused by ford dealer but it didn't help. any ideas? thanks
Old Feb 18, 2009 | 09:55 PM
fairlaner's Avatar
My '99 w/ 4r70w trans shifted very late/hard into 2nd, caused by a broken 1-2 accumulator spring (cheap/easy repair). I don't know if your '05 has the same trans or if this is your problem, but it might be a place to start.
Old Feb 18, 2009 | 10:27 PM
Blown F-150's Avatar
You should search "1-2 hard shift" and you'll find it a problem that comes up in our trannies. The 1-2 upper a lower accumulator springs are a really good place to start. You only need to drop the pan to access it.
Old Feb 19, 2009 | 06:31 PM
I purchased the 1-2 accumulator springs today from the dealer and i'm going to give it a try. I wasn't for shure if the spring problem affected the 4r75 like it did the 4r70...I think their pretty much the same trans though?
