Op Temp in winter
Old Jan 20, 2009 | 03:09 AM
Camarothatcould's Avatar
Op Temp in winter
I FINALLY got my trans temp gauge working. It reads from 120-300*F. I just made a 12 mile drive, ranging from 30-55MPH, stop and go. Just as I was turning into my driveway the needle moved up and got just above 120*. ITas about 17* outside
Does that seem ok? 4R70W
Old Jan 20, 2009 | 03:37 AM
Fifty150's Avatar
Considering the ambient temperature, you're doing just fine.
Old Jan 20, 2009 | 07:52 AM
phil6608's Avatar
Mine starts at 100* and lately with the cold temps,,it very rarely moves off of 100*
Your ok,,,not going to hurt anything.
Phil
Old Jan 20, 2009 | 08:07 AM
thanks guys!
Old Jan 20, 2009 | 01:51 PM
As long as it's above 95, it will be fine. That's when it allows it to go into OD and lets the TC lock.
Old Jan 20, 2009 | 02:49 PM
grizzstang's Avatar
When I was driving around in the -25 degrees C (I am not sure what that is in F so let's just say really frikken cold) my gage was only getting to about 55 degrees F (my digital gage goes from 0 to 300). It shifted, ran fine and would go into overdrive but when it was that cold I turned overdrive off. I have a thermostat to put in but it only opens at 180 degrees F and I kind of like the that it will go cooler than 180 in the summer. I am torn as to whether or not I should put it in. Any thoughts?
Old Jan 20, 2009 | 02:59 PM
MudTerrain's Avatar
When it's cold, on the highway, my is right around 100F.
Old Jan 20, 2009 | 03:25 PM
Fifty150's Avatar
If it's really bothering you, you need to relocate that driveway. Try California. Your temps are sure to climb.
Old Jan 20, 2009 | 03:43 PM
It reached 150 going to work today. I than pulled in the parking lot and idled for a few mins. I watch the gauge go all the way below my 120 mark. . .
Old Jan 21, 2009 | 04:06 PM
Temp flucuates like crazy
