Clutch help
Old Nov 1, 2008 | 08:14 AM
flt04lee's Avatar
Clutch help
i have a 91 f-150 5 speed man trans...my clutch pedal is grabing at the very top of its travel. just replaced a worn plastic bushing in the end of the clutch pedal rod but no big difference. some guys say you cant bleed the hyd clutch and some say you can. i need this fixed asap.iam slowly loosing my clutch.
Old Nov 1, 2008 | 09:54 AM
If it's grabbing right at the top, it's very likely it's simply worn out and needs to be replaced. Yes, it can be bled, it has a bleeder screw.
Old Nov 1, 2008 | 10:33 AM
flt04lee's Avatar
the guy i bought this truck from said he replaced the clutch and had the flywheel cut . iam not sure about the bleeder i asked him and he said you dont bleed it. were the hyd line goes into the trans theres a brass looking bolt above it with a hole in it but no lil bleeder fitting in the middle so iam not sure if this is a bleeder or not.i just bought this truck so iam new to it..the clutch is not slipping at all..
Old Nov 1, 2008 | 12:01 PM
If it needed bleeding, the pedal would be low or it would fade - not engage at the top.
