will this hold?
Old Jul 30, 2008 | 06:01 PM
600Polaris's Avatar
will this hold?
i did a little red-neck fix. my tranny line rotted through and was leaking, so i cut out the metal line and took radiator hose and hose clamped it down,
what im wondering is if the fluid will eat through the hose and if it eats the hose if it will spoil the fluid. im pretty sure it is not a high pressure line, so the clamps will hold,
any one do this cheap fix yet?
Old Jul 30, 2008 | 08:39 PM
fireman28's Avatar
That is the same way the dealer would fix it if you took it to them. I have read other post of the dealer charging a small fortune just to do that same fix.
Old Jul 30, 2008 | 09:31 PM
keith97xlt's Avatar
use tranny cooler hose and use 2 good clamps on each end. ive fixed many rotted lines that way. flaring the ends helps also if you have the tool.
Old Jul 30, 2008 | 09:55 PM
dirtyd0g's Avatar
Without flaring the line it is an accident waiting to happen. The trans fluid will turn the standard heater or fuel hose into mush.
Alan
Old Jul 31, 2008 | 06:08 PM
keith97xlt's Avatar
yea u gotta use that tranny hose. autozone,advanced ,napa etc.. all sell it for a few dollars a foot.
Old Jul 31, 2008 | 08:04 PM
600Polaris's Avatar
ill get the tranny hose, no problem there but what is this flaring?
it it just opening the line and tapering it out like one of those pilgrims shotguns on turkey day in the cartoons or what?
Old Jul 31, 2008 | 08:10 PM
600Polaris's Avatar
also, i lost a lot of fluid. but when i check my level it says do not add. but it is lower than normal, i check regularly and theres a fresh coat of fluid on my frame, rust prevention ill call it, but ever since i got my rebuild with a built up tranny it nas had a higher level than stock. it has been shifting harder than usual so is it safe to put the fluid back up to where it was?
it does have an external mounted cooler and filter, the tranny place added another cooler and another filter, so because of this wouldnt i need more fluid?
Old Aug 1, 2008 | 09:11 AM
MitchF150's Avatar
How are you checking the level? If you are just pulling the dip stick with the engine off, then you won't get the correct level.. Must have engine running, move gear shift thru each gear for a moment or two. Fluid at operating temp and then check the stick.
Not too sure on running two tranny coolers?? Isn't it better to get a larger SINGLE cooler? Add on filters are also something I've heard you don't want to do either.... Something about losing too much fluid pressure, or building up too much pressure before the filter??
How does an aluminum tranny line 'rot out'?? My 97 with 187,000 miles on it does not leak a drop??
Good luck!
Mitch
Old Aug 1, 2008 | 03:50 PM
600Polaris's Avatar
i checked the fluid right, just after my commute in park running.
larger cooler not two coolers, an external mounted filter was added.
so i was thinking it would take more fluid, at least hold more.
as for rotting out, it was corroded and the fluid was streaming out of it, chit happens
Old Aug 1, 2008 | 04:52 PM
keith97xlt's Avatar
all lines eventually will rot out and leak.its better to flare but. youll be ok as long as u use good stainless hose clamps you want a good 2-3 inches after you slide it on the hardline for good clamping.
Old Aug 3, 2008 | 07:56 PM
600Polaris's Avatar
all right, thanks all for the help.
Old Aug 3, 2008 | 08:04 PM
f150fella08's Avatar
haha thats how i do it at work..when i do a tranny service and change out the fluid we sometimes cut the lines and use rubber hose to mend it back together hahaha
