Torsion bar removal???
"97 F150 Lariat ext cab automatic tranny.
Is it as simple to do as removing the load/tension and then tapping them out, minus any rust issues holding em in? I have to replace my output shaft adapter on the rear of the tranny to the front of the tranfers case and really don't want to remove everything. I was hoping to take the xfer case loose and slide it off the shaft and then slip in the new adapter...doable? How much does the xfer case weigh? Thanks, MM |
its pretty easy getting the t bar bracket off... leave the bars in the A-arms tho. I just R&I'ed my tranny, and put the transfer case back on just by laying on my back, its an easy 100lbs.
