Clutch Squeaks When Pressed In
Old Jun 22, 2008 | 09:41 PM
NickM86's Avatar
I have a 86' F150 that has a 302 and a 4 speed. When I press on the clutch going to change gears or to even just start the engine it will squeal but once its started and i have let off the clutch it stops. I replaced the slave cylinder a while back in hopes of it to stop the squeals. But when i crawled under to check the tranny fluid it had a mix of Automatic trans. and Gear oil in there and was thinner than burnt motor oil. Also will this truck be able to pull a 16' trailer with 5 4'x5' 900# round hay bales? Thanks Nick
Old Jun 23, 2008 | 06:26 AM
scouty's Avatar
Maybe a throw-out bearing??? I was told that is what went out on my ranger. It would squeel when the clutch was depressed. my brother fixed it and the squeel went away.
Old Jun 25, 2008 | 12:33 PM
Which 4 speed?
Get the code off the door sticker and look it up in the sticky.
A squeal when pressing the pedal with the engine off could be a throwout bearing, slave cylinder, master cylinder, or pedal linkage. Squealing while the engine is running and the pedal is NOT moving is the throwout bearing or pilot shaft bushing.
